Kegger
R.I.P. 1/12/1966 - 6/1/2017
Trying all those xovers should be very imformative and I for one will be really looking
forward to your impressions.
Personally I feel the one you posted first (1.5 coil on woof) should give the drivers better
xover points for there strengths and sound the cleanest.
I think that the differences you will find between all these xovers is the xover points
themselves will be quite different, also you may find on some that multiple drivers will
be running at the same frequency which will more then likely give you more volume
for a given amount of power but at the sacrifice of not being as clean of a sound.
Also the one with the 1.5mh coil will take some of the upper frequencies out of the
woofer which should be an improvement and keep the lower midrange frequencies
from being produced from a woofer that is to large to produce them "correctly" but
also will keep them out of the port because the woofer will not produce them.
Just a few things to try and listen for when you evaluate these. Not that you want to
but I would be very greatful if you took some killer notes when you listen to all of these
and report back on each one. As I'm going to redo my xovers and some of your info could
be very helpful for anyone wanting to improve there's as well! Yes all my electrolytics
will be replaced with quality poly's.
