angelaudio
I have an 800-C that I got in non-working condition. It was not powering on so I immediately suspected the power knob as it wasn’t making the unmistakable “click” that it should. It is unrestored and it doesn’t look like anyone has ever done any work on it.
I proceeded to pull the power/volume assembly pot and could see a burn mark on one of the tabs
So I took a working volume/power switch from a donor 400 and soldered it into the 800-C. I powered it up on a variac and noticed that one of the AM 455KC transformers was arcing so I shut it off and clipped the leads that were going from the 455kc IF to pin 4 & 5 of 6HR6 which stopped the arcing. I then got all pots and switches cleaned up and after another listen I noticed heavy distortion, hum and less volume on the left channel.
I swapped the GE output tubes as well as the 12ax7’s and the problem persists. I toggled the tape monitor switch back and forth to no avail, same issue. Listening through the headphones made the distortion go away but the hum was still present. Sounds like 60hz hum. I have only listened through the aux using an iPod thus far and I’ve not tested the other inputs.
What could be the issue here?
