Longaevus
In order to properly feed a pair of JBL's Ti-3000 I recently traded, I purchased the aforementioned Carver power amp only to find out two strange behaviors:
A) buzzing speakers - the speakers have a permanent buzzing sound that increases when both/either left and right gain controls of the amp are used. As I have investigated this is probably due to a ground loop somewhere. I have tried to connect the amp directly into several different wall outlets in the house to no avail. Not that it hampers the ability to listen to music but with quieter genres it is audible and of course, annoying, as it shouldn't.
My only guess right now is that the XLR»RCA adapters somehow are bad quality ones and a ground loop is occurring, as far as I know XLR cables/connections are balanced and properly ground isolated contrary to the more common RCA. Could this be fixed by returning the adapters and getting proper XLR»RCA cables?...
B) humming amp - after trying to solve the buzzing speakers problem with no luck I noticed something that feels a bit more troublesome. Upon powering it, the amp hums quite a bit, it can be heard from a few feet away, louder than the cooling fan for example. My bet is that it is transformer related but I am ignorant to electronics and have no idea how to diagnose or fix this.
I know the amp is old but it should be a competent one if in good working order, my fear is that I have been sold a faulty amp which repair will require a large investment that does not make sense financially.
Any help would be DEEPLY appreciated guys
