Not the bass (60 Hz) kind, more like the baritone (120 Hz) kind. Heathkit SA-2 integrated amp. I just replaced all the electrolytic, paper, & oil caps, and some resistors. Tubes are all back in their original positions. Now I have a fairly loud (noticeable @ 6 - 8 feet away from not-very-efficient speakers) hum. It is in both channels, constant volume regardless of the input selected, output selected, volume or tone control setting. I have rechecked all my work, and all the solder joints, so far no luck. Transformers & rectifier tube are all running cool, no other issues except that the phase reverse switch doesn't work (reversed gives no sound). Thoughts on where to start?
