System:
Krell KAV300i B&W 804s HSU STF2 Audio Innovations Phono preamp Schitt Modi DAC UB9000 UHD Player (with DAC)
A few weeks ago I was watching a movie and heard slight crackling coming from what seemed the left channel tweeter. I did some frequency sweeps and tests to see if the tweeter was fried. I was concerned because I had purchased the speakers only a few months ago and the tweeters they came with were dented so I had replaced them. In short, the tweeters weren’t that old.
So I suspected that maybe the amp is getting long in its teeth and needs to be sent to Krell for a refurb. Krell is currently closed after having lost their CEO in the last couple months.
In the meantime, I noticed that the left and right channels were not perming consistently. The left channel would seem to struggle to reproduce pink noise during a test. Like it’s being starved of energy.
I ended up buying an even older amp (NAD 2200) as a stopgap while waiting on Krell. It’s producing the same issue!
I’ve tried multiple things: different interconnects, new tweeter, with the sub in and out of the chain, removing everything but the UHD player as source. Everything but the MODI as source. The issues are never completely reproducible and sometimes show up in the right channel as well!
I even tried another pair of B&Ws I have. I’m so freaked out. I don’t know exactly what the issue is. If something has killed the cross overs in both of my pairs of speakers or in both speakers.
I use the sub in “augmentation mode” as in I run speaker cables from the speakers into the sub since the Krell does t have a sub out. I don’t trust the sub because of the way that even in this “mode” I’d experience some weird **** (noise coming out of the speakers while the Krell was off). When the sub was set to “auto on” in the past sometimes it would starve one of the speakers in a similar fashion to what I’m describing above and then it would come back after a slight “shock”. But even taking the sub out of the chain I’m getting the same issue.
I just want to know what’s broken so I can fix it. I can’t really get into the 804s crossovers. I don’t mind calling B&W but I don’t want to go down that path if it just happens to be that both of the amps are ****ed.
Anyone, anything, please?!
