I asked OpenAi about tracking force...
ejman
Wow. If this is experimental I wonder what it will be like when it's really developed.
Me: is 3 grams tracking force too high for a conical stylus?
OpenAi: A conical stylus typically has a recommended tracking force between 1 and 2 grams. A tracking force of 3 grams would likely be considered too high for a conical stylus and could result in damage to both the stylus and the record. It is important to always follow the manufacturer's recommended tracking force for your specific stylus.
Me:I see. Are you sure? I know elliptical stylus require lower tracking force but I thought a conical would be safe at a higher tracking force I seem to remember much higher tracking forces when LP records were first released back in the 50's
OpenAi: You are correct that in the past, when LP records were first released, tracking forces were generally higher than they are now. Conical styli were often used with tracking forces between 3 and 5 grams. However, as technology has improved, it has been found that lower tracking forces can result in less wear on both the stylus and the record, as well as improved sound quality.
It is still possible that a conical stylus can be used with a tracking force of 3 grams without causing damage, but it would be best to check with the manufacturer for the recommended tracking force for your specific stylus. It's also worth noting that if you're experiencing distortion or other sound problems, you may want to check your tracking force and make sure it's not set too high.
I don't think 3.0 grams is too high for a conical stylus if it is at least a 0.7 mil. I would not use a 0.5 mil at 3 grams. Some elliptical styli are used at 3.0 grams. It depends on the tip profile.
