jazzmans
I just can't keep away from these carver amps, I've owned my M1.5t since 1993, owned two PM 350's since 2007(ish), owned a PM 1.5 since 2009(ish), TFM-15 since 2007, TFM-25 for about three years now.
All amps are in daily use except the TFM-15; it's the only one that isn't a magnetic field (with Triac) amp. Sounds great, but only(!) 100 wpc, so it's my 'backup' when another amp starts performing badly. (they're all old, and parts do wear out requiring repairs)
So, I found a cosmetically beat to hell PM 1200, the biggest baddest carver Pro series amp Carver built,(I Think) 450 wpc @8 ohms, 600 wpc @ 4ohms (where I'll use it, as most of my speakers are 4ohm), and a mind boggling 1200 wpc bridged. It's somewhat comparable to the mighty TFM-75 which I'm sure I'll never find, and only second to the Lightstar, and/or the Sunfire Signature grand.
Which amp should I replace with it?
1. PM 350 directly coupled (no speaker switcher) to Infinity Renassaince 90. (bedroom and my best speakers only used when I want the best sound for focused listening)
2. PM 1.5 directly coupled to Magnepan 2.5R (living room used every day)
3. M 1.5t directly coupled to Magnepan 1.6QR (office computer speakers used every day)
4. PM 350 through niles speaker switcher driving Infinity RS 2b, M&K S80, KEF LS-50 (living room, kitchen, used every day, usually in conjunction with PM 1.5/Magnepan)
5. TFM-25 through russound 12 way speaker switch (with autoformers) driving Infinity RS 4b, Canon Fonum 200, various outdoor speakers(4 pair atm) used every day for 'casual' listening while I putter about the house doing stuff.
Of course, this (should) go without saying, after I check it out and ensure it's performing according to spec, and clean up all the old tape/sticker goo. Pics to follow once it actually shows up.
Note, None of these amps are driven to their limits much, if ever, I've seen the PM 1.5 max out, once or twice, but I've also blown the fuses on my Maggie ribbons, so I don't think it's underpowered. I've seen the clip light illuminate on my PM 350(4.), but only once, and I was listening stupid loud. I've never maxed out my first m1.5t on my maggies, the sound gets intolerably loud before the amp runs out of steam.
I've also never maxed out the TFM-25, but I have presented it with obscene ohm loads before. (I keep the autoformers set to two speakers output, but have occasionally driven 7 pairs simultaniously. The stability the TFM-25 is famous for into low ohms is why it is where it is.) I've never maxed out the PM350 (1.) and likely never will.
all the PM series have 'clipping eliminator' on them, which lowers the input up to 8db when the amp enters clipping, therefore keeping the amps from destroying speakers. The manual on the 1200 actually says, and I quote, "it saves speakers, Use it"
On further reading of the various manuals I've found (funnily enough, I've found two different user manuals as well as the service manual) It's at heart a PM 1.5 that's been beefed up with additional transistors. Wonder if it sounds the same? All my Carver amps have a similar sound.
Anyway, anxiously awaiting the amp! It's already shipped.
