Fair enough, thank you Jon_Logan for your honest reply based on personal experience. Doesn't get any better than that.
Out of curiosity, do you think that all preamps sound the same?
There can always be exceptions, but as before, electronics that are decently designed, can work into the loads that are connected and don't have any failings in terms of frequency response, THD, and to a lesser extent phase vs. frequency, than I could answer for myself: no, I don't hear the differences.
I've personally done an experiment on wire and power amps and the result was the same under the same test conditions... zip, zero, nada. The first test case (which I thought I'd be able to tell the difference) was with wire. 100% silver Mark Levinson wire against Gold-enz. No dif-france when switched back and forth. Next power amps. I had an SAE Mark 111C and a Levinson ML-3 (serial number 0072). Vastly different topologies. Maybe the most different two solid state amplifiers could be. I was SURE I could tell the difference. I knew enough that they had to be switched quickly and the levels had to be matched. I did that and guess what?? No dif-france.
It could be my hearing or my skill at Golden Ear'ing but I'd like to see some proof if it's my shortcoming or if people have just convinced themselves that they "hear" things based on placebo effects and ego.
Now, I would never say the same things about speakers. I hear speaker differences all of the time. The errors in speakers are magnitudes greater than the errors found in decently designed electronics.
While I am curious if people can hear differences in wire, preamps and CD players, my conclusion is these things aren't necessary for superb sound. Speakers and room tuning is where it's at for me. Don't get me wrong, I'm a gear slut as much as the next guy. I love copper buss bars, thick faceplates, big heat sinks, the whole nine, but that's pretty much eye candy. If the design is sufficient for the application, that's good enough for me. I'll buy the more expensive electronics after I win the lottery and need to boost my status level.
