I really appreciate the genuine suggestions made so far. It's odd to me that a few people add to this thread making incorrect assumptions about what I have or have not done.
In the first post, I have included a sample of the sound I like with substantial frequency extension & described the attributes of this sample in the ways I perceive them. Here it is again.
https://gofile.io/d/Hw6Cmw
My hope is that someone would take the time to listen and then suggest a preamp that has those characteristics. That would be extremely helpful.
Well, I listened.
But, frankly, the notion that someone could make a valid suggestion based on that is totally flawed. That's because everyone listens to the sound sample through their own system, and each and every one of them is different.
And we all listen to
systems, which include different amps, speakers, rooms etc. While we can try different components in our systems and hear differences, it's very difficult to determine how much a particular component (in this case a preamp) will affect the overall presentation of
someone else's system.
Perhaps this is especially true in the case of preamps.
How many times have you heard people say the best preamps are totally transparent and add nothing to the "sound". Not saying I agree with that. The preamp I built, the Boogie Factor 1626, does add something and I like the result.
https://www.audiokarma.org/forums/index.php?threads/1626-preamp-build.931276/
I have no idea how it measures and, frankly, I don't care. I also have a Yamaha C-85 and I'd say that it comes close to not having a "sound". My experience with preamps is limited, though, so perhaps it sounds warm compared to some others.
But I suspect that many people would say that, compared to other elements in the system, that the preamp often has less influence.
Based on the description in your initial post, I'd suggest you try something that uses DHTs, directly heated triodes. I'm into DIY but I'm sure there are commercial products that use these types of tubes.
For my most recent amp build I ended up using 26s on the input but during the breadboard process I tried numerous other DHTs and triode strapped DH pentodes.
https://www.audiokarma.org/forums/index.php?threads/the-nuance-my-inverted-set-diy-project.990205/
Most all of them sounded nice but the 26 had a combination of warmth and detail that I found very appealing. To my surprise, I also found that there was quite a variation between the ST shape 26s and the older globe style version. The STs were warmer, bordering on lush, while the globes were more detailed and can be downright spooky when it comes to sound stage.
But, again, that's in my system and YMMV, as always. And my implementation of the both the 1626 and the 26 is in a super simple circuit. In a more complicated circuit they might sound somewhat different.
