This is my first amp, I studied both Cordell and Self. I experiment with very high loop gain this time, just one way to start. I just want to finish one amp first and then plan on others later. I finished my first version on a wood board and did extensive comparison as shown in this thread: http://audiokarma.org/forums/index.php?threads/does-a-good-and-expensive-amp-matters.757185/
My amp is complementary IPS with current source load, darlington VAS and tripled EF OPS with high current bias satisfying Oliver's condition. The Nakamichi is the Stasis design with no GNFB. Two polar opposite design sounded exactly the same. That make me question how important is the power amp if they are beyond certain standard. I don't know, only way is to build another one polar opposite like the Aleph by Pass. And then a tube and compare.
I need to study and simulate the Technics circuit after my amp is completed. I did research a few patents and simulated them, absolutely no luck, the distortion is very high in different ways, my conclusion is there is no free lunch. Particularly when I adjust the bias and look at the FFT, it's really not as much difference as I expected. Between Oliver's condition to class A, difference is really minimal. If FFT shows minimal difference, From my extensive experiment, I doubt I can hear any difference.
I don't know the group delay, but my amp is also very fast, large signal rise time is like 0.8uS and no noticeable overshoot with 4ohm load. But there's just no difference in listening. You see in my thread I experimented with 3 pairs of speakers. The speakers sounded day and night difference, but identical between the two amps. The more disheartening thing is the Acurus 200X3 that is supposed to be much lower grade, sounded very closed that I had to switch back and fore quite a few times to make the claim.
I am actually thinking about lowering the idle current, change the emitter resistor from 0.27ohm to 0.33ohm or higher to meet the Oliver's condition and run the FFT and see how much different is the THD. That way I can raise the rail voltage to get more power to avoid clipping all together. I was on DIYaudio before, people like the popular Honey Badger and a few others all run lower idle and keep at class AB and raise the rail voltage and speed up the amp. This is their concept and they apparently are very successful. Maybe there is some truth on that. I am experimenting towards that.
EDIT:
For the fun of it, I just did experiment with emitter resistor of 0.27ohm that the oliver's condition is about 100mA/stage and 0.09A total idle current. I run 10KHz, output is 22V peak ( 44Vpp or 15.5Vrms), the rail is 31V with bench top supply, driving 4ohm load. So I am driving 60W with +/-31V rail, that's quite high already.
I lowered the idle current down to 0.6A, THD is 0.01034%, I then raise up to 2A and THD is 0.00975%. At 1A, it's about 0.01005%. So you see very little distortion change with big change in idle current. This make me question all the fuzz about the idle current as long as you get a little of class A in the middle.
Maybe the key is to have lots of output stages. Self showed distortion is minimal if load is above 32ohm driving by one stage. Which is 16ohm for two stages, 8ohm for 4stages and 4ohm for 8 stages.
EDIT:
