I'm currently working on a Sansui R-99Z that has some real issues. As soon as it powers on a faint, crackly signal comes out the left speaker but quickly (5 seconds or so) fizzles and goes completely quiet. This is a later model Sansui, and the power amp is completely contained in an STK2139 IC, which I suspect is my culprit. There is, however, another IC labeled "Voltage Amplifier" which has given me pause... possibly this one has gone bad instead or as well? I don't work on this type of gear with integrated circuits often, but from my research the IC's seem untestable with a MM and I would rather not buy $20-30 in parts on a hunch, so I'm hoping for a bit of advice on where my problems may be stemming from. Are any of these parts notorious for going bad? Is there in fact a way to test an IC? Or is there possibly something else painfully obvious that I'm missing?
Thanks!
Thanks!
