Sam08861
Hello,
I've recently acquired an Ampex 1455 and it seems to be functioning for the most part. I don't have any reels yet to test out but, I'm giving it a good cleaning (heads, rollers, dust!, etc.) and lubrication.
The player/recorder has one motor, 2 capstans and auto reverse with 4 heads (labeled play fwd, play rev, record, erase)
Sooo to get to the point, here's the problem.
The left wheel/hub behind the supply reel spindle was ticking loudly when playing in reverse. Taking the mechanism apart and giving it a good cleaning took care of that.
What seems to be causing all the problems is this bright blue tarry substance. Removes with lots of elbow grease and gobs of isopropyl. A small bit seems to saturate a full hand towel, lol.
It's on the red wheels that engage the wheels that are on the same spindle as the reel hubs. Not sure if these are idler wheels or not, but not sure what to call them.
Some photos..
same shot not spinning...
Anyone know what this is? Is this a rubberlike gasket that has deteriorated? That stuff gets on the white wheel and acts like speedbumps, causing the whole mechanism to click or vibrate.
Cleaning the white wheel makes things smoother, but I think I need to get to the blue gunk on the red wheel. Stuff is stickier than just about anything and doesn't dry up at all.
If this is a part that's deteriorated, I'd like to replace it. If its something else that perhaps the previous owner tried to make the wheels sticky, I'll just get rid of it.
Haven't been able to locate any info on the web so hoping someone here know.
Any help appreciated greatly!
Thanks,
Sam
Some photos..
Thanks,
Sam
