Identify this speakers
The woofers identified on the sheet from Audax would probably be hard to find anywhere. If you're lucky you might find enough about them on the web to help select a suitable replacement.
One can test a driver for polarity with a small battery, 1.5 v (on google there are recommendations for a 9v battery but many at AK warn against the higher voltage.) though I don't know if those mids and tweeters will have enough visible movement to tell.
If you're up to a little work you can test the coils to see if they match the values on the Audax sheet. If they do you have the most expensive components needed to build that crossover.
What you need is to find the T/S parameters of that woofer, then find another woofer with similar specifications.
Anyone know if Audax data is available anywhere in particular?
