Well, I've gotten a bunch of helpful info off this site in the last few years (thanks!), and hadn't had anything I thought useful enough for a post until now so...
I have a Dual 1218 turntable that had an old dried out rubber idler wheel. Tried all the suggestions of soaking in to try to fix it, that didn't work so I tried sanding it and that didn't help either.
Because the diameter of the idler wheel doesn't affect the speed, achieving a precise original diameter match isn't critical - it can be just close enough and you'll be fine; like +/- 1/32"
Anyways, what I did was attach my idler wheel to my dremel (a drill or anything else where you can create a balanced rotation will work) and I etched a channel into the outer rim of the idler wheel in which I placed an o-ring from the plumbing section at the hardware store. Presto! Good as new, and replaceable! Hope this helps someone!
The only thing to watch for is when putting the platter back on, that the contact edge doesn't push the o-ring down and off while the platter is loaded back on.
Pics:
Original
W/channel
Installed w/o-ring
Pics:
Original
W/channel
Installed w/o-ring
