The Tacet is better for anti-skate settings
You can't really use a test record for anti-skating settings because the skating force is highly dependant on the modulation of the groove (signal strenght) and all anti-skating test records are either based on no modulation (blank record) or modulation that is way too high (to the point that there is loss of contact to the groove wall).
Both are not representative for normal signal strenght thus per definition you'll end up with the wrong antiskating setting (as in too high, but unknown how much too high).
That said, the 'right amount of anti skating force' is also a question in itself. Is the right amount of antiskating force the compensation force during quiet passages in the music, or during 'average' music strenght, or during maximum music strength (usually the chorus in pop music)? Also different records from different era's vary quite a bit in this sense, but they are never on the level of a test record modulation track to set antiskate. That difference is easily 3 times that. We're talking about regions of +12dB from a level that is virutally already never seen in the loudest peaks normal music.
As for resonance testing, the Tacet record has a really strong resonance track, which results into an interesting insight tot the point that stylii can loose groove wall contact or even jump the groove. However, that is also not a real world scenario. Both compliance and damping don't have to be the same per say at the extreme amplitudes of the cantilever suspension as they are at minor amplitudes. For real world implementations and experimentation, a test track from say the Firato test record is more useful.
Those tracks have way less amplitude and also miss their pilot tones so they are purely ment for research with an oscilloscope or spectrum analyzer but they represent a more representative situation that could occur at normal playback.
Won't make much difference in the resonance frequency but it would in determining damping characteristics of suspension.
