jstwhln
Let me start by saying that I'm a glutton for punishment and that this is the first Dual 1249 and the third record player I've worked on.
I picked up a Dual 1249 that was having the typical "tonearm lifts but doesn't move" problem. So I purchased a new steuerpimpel from a guy that sells them on eBay. While I was waiting for it to arrive, I carefully took apart, cleaned and lubricated the mechanism. After installing the new steuerpimpel, the tonearm lifts and moves, but it goes all the way to the point at which the stop cycle is triggered. Once there, the tonearm will set down, pause, lift and return to the tonearm rest and the TT will then turn off.
I've tried adjusting the tonearm indexing screw (under the Dual logo) to no avail. I've also tried going through the automatic cycle with the tonearm locked down on it's rest.
Has anyone else ever had this sort of problem? I've looked through the forums, and most problems seem to be the "tonearm lifts but doesn't move" type of problems.
