Avmn565577
Could I get by with an inch above and below and a 1/2 in in between. I’m not sure what your suggestion of overlapping is, no space?Mine are 18“ tall, 24-1/4 wide and 25-1/4 deep, but I did a custom build to fit a 15“ passive radiator in the back. I have 1-1/2“ space above the L-Mahl and below the PRV WG-4550 on the motorboard. If you’re not doing the passive, you could get by with 15-1/2“ high motorboards or less, if you overlap the tweeter and mid horns.
I was going to go with a 3/4 in mdf, hdf(if available) or plywood baffle. Is there a preference? Also I was going to use a router for a channel to fit the baffle, recessed enough to make a magnetic grill fit flush. I’m just trying to get all the details figured out as much as I can before I measure 5 times and cut 2 or 3! lol! Any suggestions are much appreciated!
