Hi Dan -- Thanks for the kind words. The components available at the large parts houses seem to change daily. The KSA10130BU is the Korean version of the basic A1013 device. Crossing this (for example) to an NTE device (the old ECG) comes up with an NTE 32. This is a 160 volt PNP silicon transistor rated for 1 amp, with a min hFE of 100, and comes in a TO-92M package. Any device rated along these lines will work just fine.
Since this was a one-off project, originally started to prove out certain elements of a "universal" EFB circuit I am working on, the board and mounting bracket all came from stuff I had on hand. The board was a portion of a larger R/S perf board, and the bracket was a small L-Bracket I had in my hardware box. I would think that the big box retailers carry small brackets that would work, or they could be fabricated easily enough from some thin aluminum stock.
The TL072 should work just fine in the buffer circuit.
I did not do any phono mods for a number of reasons:
1. Those circuits don't impose the significant compromises made in the power amplifier/power supply sections that I was dealing with regarding the screen dissipation, phase inverter drive, feedback/stability circuits, and input stage Miller considerations.
2. The modifications to the line/tone stages were primarily based on bringing the 400 into the 21st century, turning obsolete features into useful ones.
3. I had to stop somewhere!
In the phono preamp section, one modification that would be useful is to convert the Tape Head input into another Aux level input which can be done with some fancy rewiring of the selector switch, and input jacks.
If you do implement any of these modifications, I'll be happy to answer any questions you have along the way.
Thanks for the interest!
Dave
