Welcome to AK
@drbubble001 , The RIAA feedback network values you wrote must need an edit, because they do not represent an RIAA network.
Having restored and retrofitted my HF-81 and HF-85 phono stages, I recommend this network as an upgrade to the original values, which are close to ideal: 2700pf//2.2Meg. Ohms & 820pf//91K Ohms. This has been objectively verified to be very accurate.
It is simple to measure R and C values with VOM and LCR meters, respectively, in order to match the parts per channel. However, retaining these values after soldering requires extensive heat sinking methods. I use very small, copper, flat bladed alligator clamps, attached to the part to be soldered, as well as attaching them to any adjacent, touching parts, to keep the precision EQ values intact.
I believe your partial schematic is from an Eico manual. I think your chosen insertion points are correct, but your labeling of start/send and return are flipped. The feedback "starts" by the .025uf cap and returns to the V2 grid. I will dig out my factory scheme and check again...
For Eico lurkers, the phono EQ circuitry on HF-85 and HF-81 Eicos is identical. The HF-81 has one stereo volume control and one balance control, with no Loudness control. The HF-85 preamp uses two volume controls, one per channel, concentrically mounted, with taps for a switchable Loudness control.
Unfortunately, the HF-85 Loudness circuitry was published in error and does not sound right in stock form. However, as a saving grace for me, these loudness taps are a great placement for a scratch filter to use with noisy discs and sources. Since the Eico volume control is directly after the phono stage, before any other inputs, it was logical to implement a high-cut, scratch filter with little to no phase shift of the signal. Usually, scratch filters, and tone controls are placed after further gain stages, causing possible phase shifts at certain frequencies, thereby adding musical coloration changes...
AudioKarma does have a superb "Eico Place" thread section, plus the Turntables section is reserved for "All Things Analog" including preamplifiers and phono stages....You might want to check these other AK sections and use the easy Search function to gather more preamp info...
