Incomplete Optimus T-120
Bajaoffroad
Hello,
I have been holding on to a pair of my grandfathers T-120's that I am interested in rebuilding. One of the cabinets are missing the mid and woofer. The other needs new foam. With half of the drivers missing, repairing is not an option. I am looking for the best replacement options. I am new to home audio so I am not sure what is okay to mix and match. Also I am going to need to pair them with a receiver. Any suggestions? Thank you in advance.
Welcome to AK.
Can you source replacement drivers from EBay or the like? The Optimus T-120 are well liked.
Thank you faber.
I'd like to stay below $150 for the repairs if possible. The receiver I will probably end up getting after.
I have searched thrift stores around me, craigslist has not helped, there are midrange drivers on ebay but I cant find a woofer. I have considered ordering an original mid.
Found minimal specs. Maybe a Dayton Classic if you can not find original.
http://www.parts-express.com/dayton-audio-dc250-8-10-classic-woofer--295-315
Or this budget one comes close to some specs but is pretty sensitive and may play too loud
http://www.mcmelectronics.com/product/MCM-AUDIO-SELECT-55-2951-/55-2951
The specifications are as follows:
Midrange
Driver Size: 5"
Voice Coil Size: 1"
Voice Coil Impedance: 6 Ohms at 500 Hz
Magnet Weight: 6.7 oz
Cone Material: Paper
<>Woofer
Driver Size: 10"
Resonant Frequency: 34 Hz
Voice Coil Size: 1.5"
Voice Coil Impedance: 7 Ohms at 150 Hz
Magnet Weight: 13.3 oz
I have a pair of mids from some Mach Two's (white cones) you can have but they need to be re-foamed.
Thank you to everyone that has responded. Those Dayton Classic's look like they would do the trick. Has anyone actually fit those in the cabinet to see if they drop in flush?
How about this one >> http://www.parts-express.com/10-square-frame-paper-cone-woofer-black--290-912
Any experience?
Rickey, I will message you for more info on the mids. Thanks
Looks like the Q&As on PE do not help much but they look like a good option
I have a pair of Realistic Optimus T-120 speakers. Woofer original spec. - voice coil impedance = 7 Ohms @ 150 hz. �Resonant frequency �of 34Hz. Is the parts-express 10" square frame woofer part number 290-912 an appropriate choice replacement speaker?�
BFletch on Jun 23, 2015
BEST ANSWER: Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
  • MattP on Jun 24, 2015
will the woofer fit exactly in my Realistic T-120 speakers?thank you
paul chandler on Apr 14, 2015
BEST ANSWER: We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
  • MattP on Apr 14, 2015
