BigBogner
Member
Hi friends, I hope this finds you well. Lately I’ve been running my powered sub into the pre-out/main in on my Marantz 2230. I’ve really been enjoying this setup, but I’m starting to miss using my reel to reel (no second tape input), and I have been toying around with the idea of adding a CD deck as well which would require a second aux input.
I ran across a HK Citation 11 today for sale locally, and it checks all the boxes. Additional tape input and adds a second AUX. But I’m wondering if it is compatible with my current setup. Now I just have a stack of questions.
First being, is this step going to be helpful in any way other than adding inputs to my receiver? I know it’s not a traditional pre-amp to basic amplifier setup so I’m not sure what differences I can expect. Does pre-amp to a receiver make sense? Is the Marantz phono pre-amp better than HK’s?
Next, would I still be able to utilize the high pass filter built into my sub if I were to use Y-cables to split the send and return signal to the amp?
Lastly, if the Y-cables are an option, it appears the HK uses a 5-pin style plug to RCA with a positive/negative for each channel. How would I navigate that? Would white and green come back to the main input?
Any help is appreciated.
