Indicator lamp for sx-939 and sx-626 the same?
syracusejim
Does anyone easily know if a sx939 indicator lamp is interchangeable with a sx626 indicator lamp? I am in need of replacing the 626's lamp and have an extra 939 indicator lamp. thanks, Jim.
Which indicator lamp? If it's the Dial pointer Lamp, maybe. Both models list the dial pointer as an assy. The lamp is not separately listed. I have both units, and I looked at the Dial pointers and they are slightly different. However the lamps themselves may be similar. Take the 939 lamp and compare it with the 626 lamp by placing the 939 lamp next to the 626 lamp while the dial pointer is still installed.
If it's the Fuse style lamps, should be no problems.
