Inexpensive Soldering Station
Mayank
Well-Known Member
Last evening my faithful SP-23 Weller soldering iron died after 10+ years of service. I'm looking to buy an inexpensive (my first) soldering station.
Does anyone has this little guy on their workbench?
Yihua 939D+ Digital Soldering Station.
It is supposed to be equivalent to 75W with temperature control 392°F to 896°F. Looks well built. $43 shipped on Amazon.
Would appreciate your feedback.
Thank
Mayank
I can recommend the «KSGER T12» for 50$ (on aliexpress, maybe amazon too?) which should be the copy/based on the original T12 type stations. Fast heating 6-7 seconds. I myself was in the same situation a few months ago. My cheap soldering station from 2010 broke, so I bought the T12. Didn’t go for the KSGER one, but got the cheapest T12 available for 30$. To be honest, it’s worth all the money. Does it’s job just fine and I’m crazy happy that I bought it. You can swap the tips (theres a lot of them), and adjust settings as auto-off, temperature steps, etc. Much info on the internet, so just google it up. I’m not a professional user though, and only use it for my hobby. KSGER is a bit tougher/has slightly better components. So KSGER would be the way to go if you use it very often.
I've been using a Stahl TSS from Partsexpress for some time now. I bought an extra iron since I usually only use two of the tips, its easier to just swap irons instead of tips. I have yet to wear out a tip. If I used a solder iron More often I would buy a Weller, etc. though.
Last week I bought one of these (Amazon):
I have 3 of their older and cheaper model from the 80's. All working without any problems. Made in Taiwan
As long as you can get replacement tips (and possibly an element) for the iron, the name on the front may not matter much for intermittent / occasional use solder stations.
Thats how I looked at it. And the Stahl has replacable tips. The cable on the iron is very flexible also. Im pretty sure the iron has a silicone covering. It holds temp well also.
I use the Stahl, too. It's seen a lot of hard use for at least six years, I'd say, and shows no signs of giving up.
I've had two Stahl stations burn up. Now using Hakko FX888D. So far so good (1.5 years or thereabouts), and a joy to use.
Was it the model without the LCD display? I had that one first. If its turned on without an iron plugged in it will burn up fast. I have a cat that loves chewing silicone covered cables. No other wires, just silicone. One day I turned it on and didn't notice the cable to the iron had been chewed through. The base burned out quick. I keep the irons hanging up now.
I bought a Yihua iron with the hot air gun. I was replacing a surface mounted component on my daughter’s cell phone and used the hot air feature. I have used it many times over about 5 years or so for soldering and hot air with no problems at all. I think I paid about $50 or so for it.
T12 and Stahl look to be the preferred stations.
As Parts Express was out of stock, for the Stahl, I went ahead and placed an order with Banggood (first timer) for the KSGER T12 station. They were offering the station with the latest software update v3.1 and at a special 40% off price.
KSGER T12 STM32 V3.1S Welding Soldering Iron Station OLED DIY Plastic Handle Ele - US$53.88
I will post my impressions when I receive this.
Thank you all once again for taking the time to give me your recommendations.
Best Rgds
Mayank
I use the Aoyue 9378 Pro 60 Watt Programmable Digital Soldering Station. Comes with 10 tips and extra heater core. (same tip fit size as the popular japanese model and same/similar programmable features, sleep mode etc.. I opened the cover and it has excellent assembly and good size t-former. .
