Infinity bookshelf speakers...any good?
fabchef
Well-Known Member
Hi gang, how goes it? i was surfing around and came across some infinity bookshelf speakers. the model number wasn't in the ad, but looking around they seem to be the Primus models (maybe the p162's?) ( they have the grill that kinda curves on top). I don't know much about these speakers, or Infinity for that matter. Are they a good brand? sound nice?
Right now i'm running some Energy 2.1e bookshelf speakers and sound nice...how might these compare?
thanks
fab
Infinity is a good to fabulous line of speakers, depending on the age and model. Do they sound good? Thousands think so, but ultimately you're the judge. If everyone thought Infinities were wonderful. there wouldn't be any other speakers on the market.
Sorry for the long post: it shows my enthusiasm. I have a pair of small Primus bookshelf 2-ways, P-152. They're exceptional, much better than I expected. Cabinets are built like bricks, and the unusual coatings (Alumina?) on the drivers really seem to work — light and fast, and free of cone/dome resonance even at high levels. They really sing, crystal clear, with good imaging and tangible soundscape.
The Thrift shop wanted $100 for them. I said to the Manager, "$100?! You're joking! Knock off that last 0, and I'll buy them." "OK," he said.
$10 well spent. I don't know how they compare to the Energy: Energy made some very good small speakers. Get both. BTW Energy subwoofers are terrific for the price, I have 3 of the 8" models. They're no bigger than the average 2-Way standmount, but spec down to 29Hz (much deeper than any other 8" sub). Perfect size for an apartment. I got them at the same Thrift for $30 each (as new).
So for $100 total, I got a very good speaker system (Infinity+Energy) with FR from 29Hz to 20KHz, compact and fairly attractive. I have better, but I don't need better.
I found this well-written, spot-on review on Amazon —
"Past experience as a loudspeaker systems designer and audio shop owner are qualifications helpful in evaluating fine audio gear. I periodically test and compare components, particularly loudspeakers. As small monitor speakers go, these speakers perform at a level far beyond their price in fact besting many comparably-sized audiophile speakers costing many times more. Critical midrange is reproduced with fine clarity and detail that rival many of the finest systems I've heard. Bass response is very good for a speaker this size as is control without cone break-up. This is due to the quality of the mid bass driver, particularly it's cone, suspension and voice coil. The crossover blends the two drivers seamlessly. Highs are detailed and clean but slightly forward. Efficiency is relatively high, providing a pleasant listening experience even with low power amplifiers. To achieve this level of performance, the designer had to carefully optimized critical parameters and most likely had access to a well-equiped lab of design and measurement tools.
"I've combined these with a subwoofer, crossing over at 90Hz, with surprising results. As I am particularly impressed with the midrange response. Whether you're an audiophile or audio tinkerer or someone seeking good loudspeakers at a very reasonable cost, you can't go wrong with the Infinity P152 loudspeakers."
A picture of them might help, especially with the grille(s) off.
Infinity made some nice speakers. Infinity made some not so nice speakers (POS early, SM later).
Thanks guys, for all your feedback. I'll wait a bit on the speakers. I've rotated my speakers around and might stick to what i have.
I really like the energy speakers that i have, along with the Athena bookshelves i have. All i'm missing is a set of mirage bookshelves to complete the Canadian API Trinity of speakers.
Update....
I went to pick up the speakers. I hadn't really checked out specs before i went. To be honest, i was a little let down when i saw them as they are kinda on the small side. They are the primus p142's (probably used as rear bookshelves), but i was surprised when i picked them up as they had some good heft to them. The drivers were in good shape and seem to be of good quality. They are a good size smaller then my Athena speakers.
I hooked them up in our dining room area and gave them a whirl. I have to say...they sound pretty good! . The bass end is not bad, considering the size of the driver, but vocals and highs sound great! I'm pleasantly surprised.
I'm wondering now...do they make the primus line in bigger bookshelves?
Thanks
Fab
Bimasta...i already had the energy speakers l, as well as Athena bookshelf speakers, both of which, sound great!
These little infinity's sound sweet for their size, seem well built.
I owned a pair of Infinities from the 1990s that I liked a lot for a long time. Before I was really in the "hobby" seriously. But still. Many good hours of listening. I like these with the front-ported design. $10? worth at least $12!!! ;)
Just thinking of which receiver should i ise? Do i keep it hooked up to my Harman Kardon hk740 or should i give my old sony str 5800 Sd a try? Hmmmm???
Update....
>>>>>>>>I'm wondering now...do they make the primus line in bigger bookshelves?<<<<<<<<
Thanks
Fab
152 and 162 have been mentioned already. The 162 is the biggest bookshelf model according to this:
https://www.stereophile.com/standloudspeakers/1007inf/index.html
thanks
fab
are Infinitys any good lol?
more realistic, the RS-325, these little speakers rock, and in the blonde real wood veneer cabs look stellar.
About $130 for a pristine pair, woofers will need to be refoamed if not already.
