Infinity Column ii woofer model?
eliascalhoun
Hey there fellas. New to the forums here so hopefully I’m posting all this correctly.
I just picked up a pair of Infinity Column ii speakers for $50 at a thrift store. Thing is I’m pretty sure the woofers aren’t original. Anyone know what model speaker I should be looking for? Not just for the woofers but for the mids and tweeters too if possible.
In the same boat, would love it if someone could post the model numbers for all driver components, at least the the front and bottom woofers and midranges.
I too would be interested in both sets of woofers (comparable replacement) for my column II's. I do have the original mid's and tweeters. I have seen info for the mid's and tweeters on this site. Do a search for Column II's and you will find that info.
In 1993 I bought a pair of new woofers for my II's but since researching here found that they were not the correct ones. I ended up with 902-2864 which are 3.7 Ohm measured. From what I have read on this site, they should be 8 ohms wired in parallel.
