This is my first post so please bear with me. I love music but am not a gear head by any means so suggestions that involve multimeters and Detoxit are probably non-starters for me.
I have Infinity Kappa 7.1 Series ii speakers driven by a Denon POA 2800 amplifier, all of which are about 25 years old. Recently the amp started producing muffled, static-y sound through the left channel. I used the toilet paper tube test (thank you, akforum) to verify that all three speaker drivers were in this condition. I reversed the connection to several sources and nothing changed. Then I switched the wires to the amp and the problem moved to the right channel proving that the fault was in the amp.
I have a highly regarded audio tech nearby (Dave Roome at AVS Audio in Torrance, CA) and he says he will look at the amp for $85 which would be applied to a repair if one is possible. My question is whether I should pursue repair or look for a new amp. The Denon is kind of a beast with 350 watts per side into 4 ohms so my inclination is to fix it. If your advice is to dump it, what would be a reasonable replacement?
By the way, I posted in the speaker forum because the Kappas are power hungry.
