If the voice coil is rubbing, it should be possible to feel that when you press (gently end evenly) on the cone. Other things that can cause problems sometimes would be a gap in the glue holding the surround, or a wire slapping the cone from inside the cabinet. If it is the voice coil rubbing, yes, you can usually order another refoam kit and fix it.
