You might find this little back and forth interesting http://archive.audioreview.com/13/0EE90FAD.php as it explains a few things about the RSIIIb's specifically and their nature. In other reviews I've read about before they have been measured to go down as low as 1 ohm at high volumes on music that goes down low. I have to watch it if I use the Kenwood M2 (220w and will blow a fuse in the 2-3 ohm range) to drive them while the Hafler DH500 (255w but will handle almost anything down to 1) just flows along quite merrily. I'd certainly be cautious of your amp choices especially if you intend to play them loud.
This isn't the first time I've heard they need extra bracing, new caps and better internal wiring but as mine have been working just fine for the 10 years I've had them I don't want to play with them just yet. I've much to learn about this hobby and will be experimenting with other speakers to get more familiar before working on these. I have had to DeOxit the pots once in that time but that's all.
I currently use an older Sansui B2101 power amp which claims 2 ohm stability (680wpc dynamic at 2 ohms, whatever that means) so that should be sufficient for anything my head can stand.
Eventually, I'll rebuild the innards with better wiring and crossover components if their sound works for my ears. I may hate them and want to go in a different direction... I'll soon find out!
Replacement woofers arrived today...
Time to get to refoaming!!
