Infinity SL-20s tweeter reccommendation
eldus
I have a pair of SL-20s in great shape except that the tweeters are dead. No sound. The internals are fine. Ive hooked up tweeters from a pair of old small infinity RS-11 (1983?) (4ish inch woofers) they produce sound. they are just a bad match.
Do any of you have any recommendations for replacement tweeters that would sound good and hopefully fit?
The original tweeters are model #902-6363
Ebay is void of listings
-Thanks
-Thanks
Hello try posting in the Infinity forum. There will be more information there with people that may have the same issue. Thanks.
Not much out there about these speakers. Do the tweeters have any markings regarding impedance?
I'm not familiar with a model called RS-11 so I don't know what tweeters you tried, but I suspect that Polycell tweeters from the SM series or Reference One/Two might fit the bill, assuming the impedance is the same.
-Thanks
IF the tweeters were used in other Infinity models or series there is a good chance that the 902-6363 number may have been changed as part of a production run. Rather than only looking for that particular production number I'd also search for Infinity tweeters with a similar appearance and specs.
Some Infinity drivers have had a few different production numbers during the course of their manufacturing run. EMITs and the venerable 5" midrange come to mind.
There's a pair on ebay now, with model #902-5226, the phase plug over the tweeter diaphragm looks like the same as your OEM tweeters.
The writing on the tweeter face plate is different.
Might be worth looking at.
