kwingylee
Well-Known Member
Ok guys:
For those of you that have refoamed the WA120 WATKINS woofer for the RS4.5. Whose kits did you use?
I looked at kits from Rick Cobb, Simplyspeakers and Midwest speaker repair. I found a number of inconsistencies.
From Rick Cobb:
I have the following two surround kit options for Watkins 12" woofers with 9.5", flat edge cones.
Foam surround dimensions??-????p/n #610-345F-1 @ $20.99
Inside diameter: (edge to edge)?? 9.0"
Outside diameter: (edge to edge) 11-7/16"
Inside attachment lip: 7/32" (Flat 1/4" attachment lip)
Outside attachment lip: 7/16"
Roll: 5/8"
Cone diameter: 9-1/2"
Foam surround dimensions -?? p/n #610-001-1 @ $21.99
Outside diameter: (edge to edge) 11-5/8"
Inside attachment?? lip: 5/16" (Flat 1/4" attachment lip)
Outside attachment?? lip: 5/16"
Roll: 3/4"
From Midwest Speaker Repair. Note that its a ANGLED attachment and not flat.
Infinity 12 inch Refoam Kit (F12-4)
Price: $24.95 – $29.95
ANGLED attachment to cone.
Fits Models Watkins, RS 1.5, RS 2.5, RS 4.5, Quantum Line Source (some models), 5000A and more.
A – O.D. of the surround = 11.625″
B – Roll ends = 10.75″
C – O.D. of the cone = 9.625″
D – I.D. of the surround = 9″
From Simply speakers, the one that is listed as fitting the RS4.5 is: Infinity 12" Foam Speaker Repair Kit, Kappa 7, 8, 9, 902-3054 FSK-12Ji. Note that its listed as Angle attached:
2 x made in USA foam surrounds:
Outer diameter: 11.625" (295mm), Roll outer diameter: 10.75" (273mm), Cone diameter: 9.625" (244mm), Inner diameter: 8.75" (222mm)
Angle attach.
From The Speaker Exchange, the one following appears to be the best fit and its listed as "FLAT"!
12″ Refoam Kit Flat – RFK12 FLAT
FOAM: OD 11.625″ (295.275 mm) – ID 9.000″ (228.600 mm)
ROLL: OD 10.625″ (269.875 mm) – ID 9.375″ (238.125 mm)
Use for Infinity 902-3054, Infinity Kappa 7, Infinity Kappa 8, Infinity Kappa 9, and more. Also used for Phase Tech with styrofoam cone. Make sure we know you are ordering for this particular speaker because we will send latex instead of glue to attach foam to cone. The glue will not work for this cone.
These are significant differences between the kits. The cone edge appears to be flat but parts of the old surround is attached to the cone at a slight angle. . OD of 11.625" for the surround is ok and are common for all 4 suppliers. There are differences in the roll ends but 10.75" may work best. The WA120 Cone O.D. = 10" and not 9.625" and 9.375". I don't want to leave it to chance and appreciate all suggestions. Thanks in advance.
From Rick Cobb:
Roll: 5/8"
Roll: 3/4"
Angle attach.
