Yeah, TTs are all I use. Currently have about 8 and am hopefully about to acquire a Thorens TD160 next week.
I'm not usually one for sentiment. I like it purely based on what it is and how it was used, but I fear the restoration process would be timey and costly and ultimately wouldn't be worth it.
As for the switch, from what I see it looks like the original on/off seitch was damaged and they added that toggle to control it.
@Panamafred put it very well
Not sure how you’re coming to the above conclusion, these old broadcast tables are very simple to work on, and easier/cheaper to refurbish than say a Thorens TD 124 (first hand experience).
Looks like it once had 3 tonearms mounted, including one where the replacement switch is at; that’s not unusual on these tables.
There’s really not much expense related to these here’s a list of things of things to do:
Have the idler refurbished or get a custom Delrin replacement made, $100 or less
New motor mounts if required <$75
New switch capacitor <$10
Clean the motor, uses the same “oil can” hysteresis motor as the big Rek O Kut’s and other broadcast tables
Clean and lube mechanism
Make a mat
The below recommendations are not required
Polish platter
Might need a new ball bearing in the shat well, but not sure of the configuration, adding a Delrin pad underneath the shaft or something similar, will greatly reduce any rumble.
I’d paint the top plate, but that’s not required….Might even have it powder coated, and if you’re unhappy with the other tonearm mounting holes, get them filled, an hour or two at a good welding shop.
That thing has 1” Oilite bushing in the shaft well, they probably won’t need changing
Now it’s ready for another 50 years of service, and worth even more money, then you can compare it to your other tables and if you decide to sell you’ll not lose anything in the process
If you do decide to sell, drop me a pm….
VR
Andy
