Hello all,
I have a Kenwood CT-2050 dual well cassette deck that I need some initial guidance on trying to repair. The deck was within a system that sat for a very long time because of an amp that was in a repair shop for a year and a half (and ultimately wasn't repair when I got fed up) and then for another untold months while I decided what to do about replacing it. The disuse led to the current curiosity. I'm thinking that it is something electronic because the symptoms are identical for both wells but it concerns the transports. The belts appear to be intact for both sides but neither well will enter PLAY mode in either direction (the machine is bidirectional). Each transport will fast wind in both directions to the end of the cassette entirely. When one presses PLAY, the heads-guides-pinch roller assembly will rise fully up to the tape for 2-3 seconds but auto-stop and retract. The capstans seem to be physically connected to the tape reel drives so I think that it is driven when PLAY is engaged (but I'm not sure since I can't see the detail of the gear connections between the plates of the drive system) but the tape reels don't move so I don't think the pinch rollers and capstan meet so there is no tape movement. No tape jamming occurs. Since the behavior of both wells is the same, I'm guessing that something in the logic is telling the system that the drives have stopped and that auto-stop should be triggered, or that there's no tape in the well and that the drive should be stopped.
I have the service manual but it doesn't tell one how to do anything (like troubleshoot), only the exploded view of the mechanism and the schematic diagram. Also, I'm not an experienced debugger/tech but a rank amateur. I know how to solder and have basic knowledge of how to read a schematic but my practical knowledge is severely limited. So, please, be very specific and dumb things down and I promise, I won't be insulted. If you're looking at the schematic of the service manual as I am, give me grid coordinates if you know them. If not, be as remedial as you can about what the specific control or area of a circuit I should look for. If it is mechanical, let me know what you're thinking I should look for. I very much appreciate all suggestions. Thank you greatly.
-Rocky_714
-Rocky_714
