inner sleeve questions
eidling
Until recently, I bought Diskeeper sleeves from SleeveTown. Then, someone (I believe on AK) mentioned a place with somewhat better prices - Square Deal Online. I recently received the inner sleeves I ordered from them and I now realize that I didn't read the item description carefully enough, because they were indeed "Heavy Duty Plastic," as in the outer protective plastic sleeves some of us use outside of our LP jackets. I've never seen inner sleeves like these before.
It seems to me their sleeves are likely to cause a bit more resistance when one is sliding in an LP. It also seems to me that plastic would be more likely to create static.
Are these valid concerns or should these be okay? Regardless, I will most likely return to Diskeeper sleeves or the equivalent in the future.
thanks!
