Oh and why do they call these borg death cube motors? I'm not sure I quite get that.
Good question. They seem to have a bad reputation, but it looks like a fairly straight forward design.
OK,…
Mopic5, Mario, of the infamous Wood Glue as Vinyl Cleaner thread has a Presto Recording Corp. Pirouette T18 record player. I do as well. We are both members of LencoHeaven (Presto, and Lenco, via Bogen, are kissing cousins from across the pond).
Mario was working on his, and I was working on mine at about the same time. We both had problematic motors. Mario came up with the nickname, the Borg Death Cube, which caused some chuckling.
I was working on mine at the same time, and had it apart a bunch of times, but kept coming up with a vibrational noise after the motor warmed up. So I'd take it apart, and try different things.
Ultimately, what worked was for me to change the top and bottom bushings, as the top bushing has worn eccentrically from the pressure of the idler wheels.
In taking it apart, so many times, the internal wire insulation had cracked and turned to powder, and because of the silk wrap wires, I was not aware of it.
I went to plug the motor in, and flash,… the wire shorted through the silk wrap, right in my face.
So, I went on line,and reiterated that it was in fact a Death Cube, that tried to explode in my face.
The Borg Death Cube came from lencoheaven, and a couple of frustrated efforts.
Can I assume you mean "thrust" pad? As in thrust bearing?Here's the trust pad from the other end of the motor. You can see in the first picture that it is worn and has a good size dimple in it. Luckily it has not been rebuilt before so I can flip the trust pad over and use the other side. Picture #2.![]()
Sure, You can assume that. opp'sCan I assume you mean "thrust" pad? As in thrust bearing?
Thanks to this thread, I've decided to attempt my first motor rebuild, on a similar Death Cube.
My first stumble is getting the four case bolts undone - they will not budge, either at the bolt head end or at the nut end. I'm presently waiting for some penetrating oil to soak into the nuts, which will hopefully unseize them. If that doesn't work, what is my next option? Heat from a soldering iron?
Mine where I little tuff getting off as well. I used WD-40 and let it soak in and it worked for me. If not you can heat up the nut. That should work. You can see that they bolted it together then painted it plus being 60yrs old.
Don't forget to take pictures of the disassembly. And if you are going to swap the bushings from end to end mark them before you pull them out. I used a small file to put a small notch in the front one. :thmbsp:
CRAP. I just realized that my Death Cube is different from yours, it has rivets that secure the end covers, not tabs. I am not up to the task of drilling them out.
I guess I will have to live with it as is, or bring it to a shop or something.
Do you have a picture of the rivets?
What do you think, Bob? Is this something a novice like me should attempt?
