One of my sons is using this equipment for the sound to speakers for his TV
Samsung 8000F TV
One Connect Box
Denon AVR 2307
TV connected to the One Connect Box. Only two set of cables. One big harness and power.
Using the optical cable from the One Connect Box to the Denon's Optical input.
All was working fine.
Until....
The sound cuts in and out and the display on the Denon for the Optical/FR FL input flashes on/off. The radio works just fine.
Tried three other Optical cables and another AVR with Optical input. Continues to have this issue sporadically.
We are thinking it is the main cable harness or the One Connect Box. Moving the wires and tapping the box will not make any difference.
Tried using the HDMI 4(ARC) out on the One Connect Box to feed the Denon's HDMI input. It is not a 4(ARC) HDMI on the Denon. No sound.
Played with settings on the Denon not luck in getting sound when making HDMI a input. Read and reread the manual and got more confused each time.
So am I correct that the audio on the HDMI will not function as input only. A composite signal of some type, like from a DVD. That the audio is buried and we need an adapter to pull it out?
He is facing some expensive choices, new box and or cables to troubleshoot this and repair. The cheapest route right now to troubleshoot. Getting a adapter to use the box's HDMI 4(ARC) out intended for a sound bar to change the signal to a Red/White RCA cable for input.
Any insight in the workings of the new improved equipment would be much appreciated.
Samsung 8000F TV
One Connect Box
Denon AVR 2307
Until....
