Going to check out an SL-1401 soon and want to make sure I do my due diligence.
After reading the manual, I am a bit confused about the strobe and what to look for. The manual says:
Could someone explain exactly what I want to look for in the strobe to verify that the speed is accurate & consistent on this TT?
And here's the rest of my checklist - anything missing?
1. Check for any obvious damage, broken/bent parts, etc.
2. Turn the table on. The LED at speed selector 33, as well as the strobe light, should both turn on.
3. Press the start/stop button. With the platter spinning, check the strobe to make sure the speed is right at both 33 & 45rpm (main line of dots should be steady, not wiggling back & forth)
4. Make sure the cueing lever moves the tonearm up & down smoothly
5. play a record, make sure it sounds fine from both channels
6. make sure the auto-return works
7. try the start/stop button while a record is playing - it should automatically return the arm to the base & stop the platter.
- The strobe dots in the middle are synchronized to the precise frequency of the quartz crystal, while the strobe dots on either side are arranged for motion in the plus and minus directions, for identification of turntable speed at a glance.
- Strobe indicator will always indicate the speed at which the turntable is moving because it is locked to the quartz control circuit.
- The dots will not show plus or minus speed variations by moving clockwise or counterclockwise as in conventional turntables.
