Sergimm
I’m restoring a vintage amplifier, and the current board I want to work on (the tone board) has a lot of cables coming from diverse knobs and switches directly wired to pins on the board. It would be a ton of work to desolder all those pins and then solder them again, and in my experience desoldering pins is trickier than doing it on normal components.
I am thinking of cutting all those cables in the middle to be able to extract the board, and then adding connectors like this to make it more convenient in the future (and not having to torture the pcb to all the soldering): https://www.amazon.es/dp/B07GXN2521/ref=cm_sw_r_cp_api_fabc_xlWPFbC8WXWZD?_encoding=UTF8&psc=1
Is this a good idea at all? What are the cons of doing something like that?
