goldear
Certifiable Audio Junkie
I believe that as a general rule of thumb, this is aways good idea from an electrical standpoint.
However I'm curios as to what kind of performance benefits (if any) one may expect from converting a point to point wired amp which connects everything to chassis ground plane to one which uses a ground-bus instead.
For example: My Eico HF89 connects everything to chassis ground. After recapping this unit, there is no hum at all, so ground loops certainly don't appear to be a problem with this construction technique. However, I can't help but wonder if this approach has compromised the sonics of this amp.
So can anybody tell me if converting an amp like this over to use a ground-buss is likely to make an audible improvement or not? And if so, what kind of subjective improvements should one expect?
