carpinus7
I wonder where you hook up the amplifier ?
Vacuum tube preamplifier is a type of electronic amplifier that uses vacuum tubes.
It converts a weak electrical signal into an output signal strong enough for further processing.
After introduction of vacuum tube amplifier, the sound can be more natural than origin system.
Name: 6J1 Vacuum Tube Preamplifier
Model:794626
Specifications:
Material: Aluminum shell
Color:Black
Input: DC 12V 1A
Adapter: AC 100-240V
Type: Preamplifier
Tube: 6J1
Features:
-Using classical 6J1 tube, design process, optimization of the line, and ultimately make it very resistant to bile
taste, warm voice and sound field open, high bass adjustment function is unique.
-Can be connected to the computer. Mobile phone.CD. lossless music player source, the output end can be connected
to a variety of digital amplifier, active multimedia speakers and other audio equipment, audio equipment allows you to instantly bile flavor.
-Support treble&bass adjusting according to different audio equipment parameters for your prefer effect !
The correct boot sequence is:Open the gallbladder front stage first, and then open the power amplifier connected to the front of the bile duct.
Please note:
This machine is a bile level, not a power amplifier, does not have the power amplifier function. Need to connect the power amplifier or active multimedia speakers before the bile level.
The tube is fragile, the installation of electronic tube, please try to slow vertical tube plug, avoid tube holes around the aluminum shell, prevent tube cracks or leaks.
Package include:
1 x Vacuum Tube Preamplifier
1 x AC Adapter
Model:794626
Specifications:
Color:Black
Input: DC 12V 1A
Type: Preamplifier
Tube: 6J1
Features:
Please note:
Package include:
1 x AC Adapter
