westend
Audiopile
I have been doing some experimentation and research involving different types of interconnects. I have been going the DIY route as I believe there is quite a bit of value in making your own and they are easy to make with even limited soldering skills. Results have been good and I've been able to pass along a few pairs to some AK'ers, besides filling my own requirements.
I was using a pretty good interconnect wire, initially, a 24ga. stranded pair within a foil and braid shield. Dielectric was polyfoam, I believe. The next configuration was a digital video cable, coaxial solid copper wire, copper braid shielded with poly based dielectric, also.
I have gotten back favorable response to both types of construction and both seem to be a step above more common interconnects. I'd like to hear some opinions of those who use solid and those that use stranded. If anyone has tried both, are there any positives or negatives to one or the other?
Also, is there a favorite type or brand of interconnect that you prefer? Is your system revealing enough for a different cable pair to make an immediate difference in sound quality? Has the construction of any particular interconnect been far better than others? What place in your system has been the best place to upgrade to a better cable? Has any cable pair been a disappointment ? If you were able to buy any interconnect what would that be? If anyone has anything to add about connector materials, soldering methods, or construction techniques, I'm sure that would be valuable as well.
I hope that this thread can be a learning experience, I know it will be for me. I can post some pics of the cables I've been making if anyone's interested in the visual aspect.
