2011etec
Watching Autoline today about engines of the future pertaining to piston motors .This company has over 100 million into development and makes sense.http://achatespower.com/our-formula/opposed-piston/#twostroke
Opposed piston engines aren't anything new,,, I was on a ship with 6 Fairbanks Morse opposed piston engines, and 3 generators that used them... The two crankshafts were the biggest cost, I believe,,, The FMs were able to be started and run in either direction...
Diesel is facing an uphill battle in America.Its doing much better in the rest of the world .Very common in Europe.
I might be missing something, but I don't see how it's inherently cleaner. If it's running ports in cylinder walls, then those tend to blow a lot of oil through the exhaust port. what about this makes it inherently clean?
Opposing pistons raise the compression, but it would seem as though having two opposing crankshafts also raises complexity. Why this config over a traditional 2 stroke?
bs
I will venture a guess at answering your question.
A traditional two stroke has the intake and exhaust ports on the same end of the cylinder. Scavenging creates a lot of waste with some of the unburned intake charge making its way into the exhaust.
The design posted here has the intake and exhaust at opposing ends of the cylinder. That in itself changes the dynamics of the flow immensely. I could envision that being very beneficial to keeping the emissions cleaner by reducing the amount fuel/air charge slipping by into the exhaust stream.
Most large Diesel engines are unifow charged 2 strokes, which require an external charging pump as they cannot "breathe" on their own...
