Today at a local GW found a Stanton STR8-80 with a Stanton 890SA on it. I realize this is a bit "post vintage" and was a DJ table but it is a very solid and nice looker which will also do 78's.
The cart is a moving iron and Vinyengine lists the output at 6.5mv.
I am assuming this would not then be OK into a phono pre-amp as the output is higher than normal?
Any other knowledge on the table or the cart as I'm going through it?
Tracking force is listed at 2-5G and there was a little screw on 2g weight on top of the headshell which I removed. After alignment should I just hit the center of that range as a first step?
