Yes and yes. Arms, too. I'm an old boomer who cut my teeth on vinyl and still maintains a modest library.Just curious...do you spin vinyl E-Stat?
If so, do you find the difference b/w carts as big as the difference b/w DACs?
I do. And to split hairs, my two cartridges - a Dynavector DV20 (unusual VPI sourced flavor) and a Shinon Red are both considered mid-output models with a 1 mv output.So you actually find the difference between a pedestrian MM and an LOMC to be as big as a Squeezebox Touch DAC and your ARC DAC?
I confess that it has been a long time since I've made such a comparison. Hearing a current Clearaudio or Soundsmith MM might well change my mind.Interesting. Honestly I cannot say the same in my experiences. YMMV I guess.
This.:yes:It has to do with the overall palpability of the sound and ability to project a dimensional soundstage.
I confess that it has been a long time since I've made such a comparison. Hearing a current Clearaudio or Soundsmith MM might well change my mind.![]()
This.:yes:
Once you've heard it, you don't forget it. It can theoretically be done with more modest gear than what e-Stat is sporting, but it's a lot harder. Excellent speakers are a must.
Hearing in three dimensions, almost seeing where the engineer has physically put all of the instruments in the soundstage, and them having enough room to breathe -- that's the magic we're after. Well, at least part of it.
And sorry, your little iPhone is not going to do that. Ever.
My Tannoys are the exact tonal balance I want in a 2-way, which is why I've kept them as my main speakers for 15+ years now. They sound rich and full and clear with most anything, and they can reach into that spatial magic with the right material and the right front end.Are the speakers you're talking about the same as in your signature?
What I remembered about these speakers in their original home was that they hold their soundstage together at extremely low volumes – this bodes well for micro-dynamics at more normal listening levels, but also allows for very enjoyable late-night listening when everyone else has retired to bed. At more ‘normal’ listening levels (around 60-90dB depending on source and time of day) these speakers really come into their own, painting a very natural image and revealing the differences between recordings like nothing else I’ve spent significant time with.
I would say the real magic with these speakers has to be the way they present vocals. They don’t do the usual high-end hifi fancy trick of making the vocal sound like it’s right in front of you and about to take your face off – and I’m aware that some might say this is a bad thing. Instead, they present vocals in a way that seems effortless and yet somehow forces me to hear every last word, and they seem to do this without obviously emphasising any particular frequency range commonly associated with vocal intelligibility. It’s almost distracting at times – a song playing in the background suddenly demands attention in a way I’ve not experienced before. That is a stunning achievement now, but somewhat surprising considering I’m listening to boxes made some 25 years ago.
Would these not be speakers you'd want to live with for the rest of your life?
The Clearaudio Concept is pretty much an AT95e. The styli are the same save the mounting. Check the stats.Well a Clearaudio or Soundsmith MM isn't exactly pedestrian.
I was thinking more of AT95e or M97xE.
Then why isn't it? The folks designing iPhone audio aren't aiming for people who can hear the difference.If it can be done with vinyl, it can easily be done with an iphone.
You left out tonal range/EQ of each instrument which is the most important piece of the puzzle.Engineers "put" instruments on the soundstage with things like panning, delay, echo, other effects. Its not physical. It is only an illusion.
And somehow Glyn Johns gets awesome dimensionality with 3 or 4 mics. Magic?A standard 3 tom, 1 bass drumset for instance, is recorded with around 9 mics.
Nothing personal, but I get the distinct impression that I've been in more professional recording and mixing sessions than you have if you believe that it's that formulaic.Each other instrument then gets recorded after another, not all together. (some exeptions of course) Guitar and bass usually 2 mics, on in front of the speaker and a directional pointed at the guitar. Then the voice gets recorded. Then the voice gets recorded again. Sometimes a third time. (All in a ton of takes) Then the next voice, same for background voices. Then it is all mixed together. This is were the instruments get "placed". True even for multimic live applications.
I didn't know either. But I found it rather shocking when it occurred to me that a $250 cart was a $49 cart in disguise.Not too sure if E-Stat was talking about that particular model.
I've heard them both back to back. They sound really, really similar. The Clearaudio has more mass, which definitely affects the presentation. But they're more alike than different.Some vigorously deny it.
