I'm sure you guys get a lot of these questions from newbies, so I hope you don't mind one more.
I recently moved. I'm using the same stereo setup I had at my old place, which includes DVR, Blu-Ray, TV, and turntable. The turntable is a Technics 1200-MK2 I got from kabusa a few years ago. It goes into a TC-750 preamp. The problem is a hum. It doesn't happen at all hours, but when it starts it goes on for a few hours. It's regular, with 37 seconds of hum and 43 seconds of not-hum. Even the sound of the hum is predictable, with a little crackle in one channel a few seconds in.
The ground wire is good (even tried replacing it). I replaced the RCA cables today with new ones. Tried different outlets on different circuits, but no help. The hum only occurs when the turntable is selected (although it does not have to be on). The hum goes away if I disconnect the RCA cables from the preamp.
I finally used the flowchart I found on your site, which suggested checking the location of the turntable within hum fields. I moved it to the other side of the stereo cabinet maybe 12 feet from it's original location, and while the hum didn't completely go away, it is much quieter.
Anyway to eliminate the cause of the hum? Or to find a way to shield my system from it? Or do I have to experiment until I find a spot that doesn't pick it up? I really hope you can help; I'm at my wits end.
