Gregory
Soundco Kid
I've been systematically doing an MC 2205 overhaul and it's in darn good shape now after more than a year of effort. However the LEFT power meter has been cutting out (it drops to zero and stays there) at low power levels. It got so bad in the past few months that the amp would power-up with the LEFT meter non-functional.
The fix was to open the meter housing, break-loose and then re-tighten the brass connector screws/terminals inside the meter movement. Yesterday I did a VERY low power test, playing Classical FM at 0.002 Watts (-50 dB) with peaks maybe 4 or 6 dB above that, and the LEFT meter went out again after ~2 hours. It came back to life by simply increasing the LEFT GAIN control from center, up near full and back.
I think the meter terminals will need some Deoxit to finally cure the problem, not just re-tightening, as it's WAY better than before but not fully cured. I mean.. those little brass screws really cracked loose with a `snap.´ What do you think about the situation? Any suggestions?
-Gregory
-Gregory
