This is related to another thread I posted about some issues I was originally having with my turntable. I've been trying to weed out this problem on and off for a while but have recently really started to get work done to solve it.
The problem I'm facing is that the left channel (always left) on the phono input will intermittently drop out partially into a crackly, staticky mess with the music just hardly legible under it all. I originally suspected my turntable, an SL-1710, to be the culprit because tugging on the RCA cables or gently tapping around the table would audibly change or temporarily fix the issue when it arose. When it was playing fine it stayed fine, even if I did mess with it. I thought for sure it had to be a problem there so I went and overhauled the whole thing, replacing all electrolytic caps on the motor board, lubing everything, new cables, and checked continuity from the end of the tonearm through to the end of the RCA cables and it all checked out great. Thankfully it spun as it should however the left channel issue persists in exactly the same way. I also think I ruled out my headshell/cartridge, swapping the L/R wires didn't change the issue, still left channel.
To try and rule out my receiver, an SX-780, as a potential culprit, I switched the RCA cables to the opposite jack and the problem STILL persists in the left channel only. To me this means the issue is somewhere in the receiver, is my logic correct? I just can't look over that tapping the table fixes the issue. I tried swapping the HA1457 chips to see if the problem would follow the chip, but it didn't. I also tapped around with a chop stick to see if I could isolate a noisy component and pulled a suspect resistor, but it tests fine and went back in. Lastly, I listened to a whole LP through an aux input and the problem never showed (but the album sounded pretty bad). Came right back when on the phono input.
I'm really stumped. I guess it could be a tiny cold solder joint somewhere or maybe a capacitor, or maybe it's still a problem with the turntable? I don't know at this point, if anyone could drop some insight I'd like to hear it. Thanks!
