markd51
Nyuk Nyuk
I agree that most use the small wet/dry vacs and that they are probably sufficient especially when used with the efficient VPI wand system. Part of my RCM build was using supplies on-hand. I had a 10 gal Shop Vac just taking up space in the garage rafters. I'm certain that it is overkill, but I wanted to have a self contained RCM for the convenience of needing no set-up to clean just one record. I'm also pretty sure that I'm bleeding off some suction where the down tube enters the tank. The other variable is the speed of the record platter. They use a 16 RPM gear motor. Faster rotation will require more passes to remove the fluid. I wondering about the flexibilty in the VPI wand. Where'd you hear that? I'm spanning mine across 2 pencils and I have to push pretty hard to get enough flex to see it. There's a little give where it joins the holder, but not so much that it will conform to the record. On the contrary mine will lift the record and make it conform to the wand.
Sorry my friend/all, that I wasn't perhaps a bit clearer with my explanations about rhe VPI Wand.
Yes, you are correct, there's not much flexure of the clear acrylic wand itself, but I do believe the entire Wand Assembly-Tower flexes a bit to perhaps aid uniform contact with the record. An ingenious (but simple) method Harry W. used, for sure.
About Vacuums. I'm no engineer-designer, but have put a bit of thought into this.
I would assume much of the difference between a 5 gallon shop vac, and a 16 gallon shop vac, is the size of the cannister, not much more.
That there's a limit as to the size-power of a vacuum motor that can be installed into any home use vacuum cleaner. They certainly cannot sell something so outrageously powerful that it's tripping your circuit breakers every time you use it. Mark
