Thanks for the link. It sounds like they send out everything in AAC format, so I am wondering if they down-rez ALAC?
"It’s great-sounding music, movies, and more to your ears. AirPods provide rich, high-quality AAC audio"
Good old apple at again!
Keep drinking that Apple Kool Aid.
Backwards compatibility?
F*ck that.. just give us your CC info & buy new everything from us every year!
Planed obsolescence?..You bet! here is just a few examples…
optical drives gone..now all of your CD & DVD’s are obsolete….Check
FW 400 obsolete…. Check
FW800 obsolete….check
USB 2 & 3 on the new 12’ mac books obsolete… check
1/8’ headphone jack on iphone 7 obsolete.. Working on it right now & preparing the faithful.
Thunderbolt 1 & 2 obsolete..working on it as fast as we can!
Most of the new tech is backward compatible via adapters. Not sure if they can still run floppy discs, but I am sure someone was pissed off when they switched to compact discs. Yes, they got rid of USB 2 when USB3 came along. It is called removing old tech for new and faster tech. USB 3 ports are backward compatible.
The Macs that have thunderbolt are backward compatible with everything above via an adapter. This makes it possible for pros with desktop computers to still have the ability to run older technology. Obviously, Apple isn't going to make computers with floppy discs and every other obsolete technology or your laptop would weigh ten pounds.
Thunderbolt 3 (via compatible USB-C ports) will be compatible with older Thunderbolt versions via adapters, as well, according to Intel.
If you don't care about new and better technology, I am not sure which brand would really suit you. They all are moving ahead and leaving behind USB 2 (as an example). Maybe just hold onto that old computer if you prefer the outdated ports or get an adapter?
As with every Apple thread, there is always a rant that takes it off the main subject. Personally, I think they removed the headphone jack this year so that they would have more room in the case when they decide to remove the bezels (there are already rumors of that happening next year). Their philosophy is that most people prefer slim lightweight mobile tech and if one port can eliminate another port (which gives them more room in the case) while still giving you access to the old function via an adapter, then it can be removed.
It is kind of like battery power in the iPhone. If it weighed 2 pounds, we could get through a lot longer without a charge. However, most people don't need it. Therefore, there are battery power banks and battery cases for those that do.
