Is increasing capacitance always preferable?
Sergimm
I'm making a BOM for a future recap of a Luxman R-1030. In the Service Manual, most electrolytic caps are listed as having a tolerance of +50% -10%. Knowing that, should I always try to generously increase the capacitance of the replacements? Most electrolytic caps today have 20% tolerance (±10%), so it looks like I have a lot of room to wiggle.
My main question is, is higher capacitance (inside the designed tolerance limits) for all caps always better? Or should I stick with the original designer values?
You might not be able to get the exact values today but I would stay as close as possible.
^This.^
Yes you should stick with the designer values - in other words the values that are in your unit now. If you randomly, and without knowledge increase capacitor values you will put yourself in a 'World of hurt' I can assure you.
Excessive capacitance in power supplies is not a good idea. Peak charging currents get larger, making life miserable for rectifiers and power transformers, not to mention high inrush currents upon power-up. The power switches often get welded 'ON', too. Use the amount the original design calls out. Small increases are okay, as an example, using 1500uF to replace a 1200uF unit.
It depends on the duty and circuit design. But for example if a "stock" cap is 10,000 -10/+50%, then theoretically you could use between a 9,000 to 15,000 and still be "in spec". Just do the math for whatever the value and tolerance of the originals.
Increasing voltage is preferable if anything.
Stay with stock capacitance ratings as much as possible.
If you want to go with excessive amounts of capacitance, which I think is unnecessary, then inrush limiting is mandatory.
