Just wondering it when others do a full recap, and/or replacing all the resistors if it might not be best to do it in stages, and then power the unit up to listen to the results. Or is it best to just go full bore and replace everything? Currently I amworking at replacing all the carbon caps with new metal caps. I had already replaced all the caps but one, an old bumble bee cap, and have been listening to it for a while.
Just thinking it might be easier to trouble shoot if I did something incorrect, to catch it at the bud if I was to do a few and then put it in the system and power it up.
Check and clean all connections, sockets, and tube pins first! This could save you a lot of work.
I go stage by stage,
as needed. The noisiest stages tend to be those with the highest gain — such as the input.
You can demo this by pulling tubes section by section.
With all the tubes in, how’s the baseline noise? Swap the rectifier tubes with a known-good one. Does the noise problem get better? Then, that is your problem.
If not, put the rectifier back in and pull the input tubes. Does the noise go away? Then the problem is in that section. Tubes, resistors, and/or caps. Check the grounding!
If not, put the input tubes back in and pull the next stage (second gain, tone stack), then on to the phase inverter. If none of that solves the noise issue, then it’s probably in the output stage (tubes) or the power supply.
I avoid wholesale change-outs. Because what if you somehow miss the culprit and the darn thing is still noisy? Yes, this does happen. It’s better to be methodical, even though it takes longer, at least in my way of thinking.
